Group: DynoMotion Message: 2319 From: Grace McKay Date: 11/18/2011
Subject: New Machine Idea- Would KFlop be suitable?
Hi guys, my first post here. I have been reading the archive and watching the live discussions for a couple of weeks.  So here is(are) my question(s)...
I am trying to build a machine for transferring super8 film to  digital files. I have a basic mechanical design and rough prototype. My choice for the main drive motor and the reel motors are currently nema 23 servos. I have a test motor from Leadshine, along with the matching driver and power supply. the driver is expecting a step/dir type of signal which I believe is the same as typical stepper drivers.  From my research so far, it looks like the kflop board and the associated software might work for my design.
If you think it might not work, can you help me understand why not? It looks like I would need to create software to run on the board, starting from the examples you give on the website. This is a problem for me -- I am not a coder, but maybe there are experts here that can help, or point me to freelancers who understand the system.  I see the lively exchange of info on the list, and I am encouraged that there is a lot of knowledge flowing.
So let me give you a little background on this project. I have been involved with film transfer for around 15 years, but the machines I have are all standard definition and the market has moved to hi-def. If I can make this machine work, maybe I can compete in the new market.  The machine concept itself is modeled after my current telecine- a BTS Quadra, http://en.wikipedia.org/wiki/File:BTS_Quadra_444_Telecine.JPG as well as a machine built in the Netherlands, that I think has some good ideas. http://www.filmfabriek.nl/home.html..
So, three motors, one is the capstan, which determines the speed the film will run through, and two reel motors. The capstan speed is constant, and the reel motors speed is variable, with feedback from linear encoders on each side, mounted with an idler roller to sense the load of the filmpacks. . I have a camera that accepts a remote trigger, and I am designing an led light that will accept or send a pulse. there will be a rotary encoder that controls the trigger, maybe.
So in some ways it is like a CNC machine, in that there are motors (3) and feedback devices to control them, as well as  the camera and light system.
So please, any ideas, thoughts, questions?
Grace McKay
Group: DynoMotion Message: 2320 From: Tom Kerekes Date: 11/18/2011
Subject: Re: New Machine Idea- Would KFlop be suitable?
Hi Grace,
First let me apologize for the 4 day delay.  For some reason this post was flagged as spam.  Maybe the links or something.
But yes sounds very doable to me.  I'm old enough to have used old HP 800 bpi Magnetic Tap drives so I thing I know basically what you are trying to do.
Seems like you could configure just as 3 independent axes.  Command the capstan at your desired speed using a Jog command.  The speed of the takeup reel motors could be ramped up or down as a function of the idler roller position.
Group: DynoMotion Message: 2345 From: quelisto Date: 11/19/2011
How fast are you going to try and do this (frame rate wise)? I certainly think what you want to do is quite possible so long as you aren't trying to do something at a really high frame rate. What also matters here is the integration time for your image sensor. The faster the integration time 9typically measured in microseconds), the easier it will be to get the mechanical system to accomodate it.
The biggest challenge will be doing frame registration. You really need to synchronize digital image capture (frame grabber) to with some sort of fiducial feature on the film itself. As you know, in a mechanical camera, frame synchronization is done with a claw-like mechanism that holds the film in registration for a standard period of time. If you do not use this type of mechanical film registration, you'll just have to do a fast image capture once you trigger on some element of the film geometry.
All of the other stuff with the film (constant speed capstan) is fall-off-a-log easy with the KFlop and any sort of motor that has feedback (whether encoder or resolver), though I'd argue in favor of a brushed or brushless DC motor for smoothness (steppers have WAY more torque ripple).
Holler back to discuss further.
> question(s)...
> knowledge flowing.
> system.
> Grace McKay
Group: DynoMotion Message: 2348 From: Grace McKay Date: 11/20/2011
Tom, thanks for the reply.
the motors will have there own encoders, linked to their own drivers, but the there are three other encoders in the system, the two linears that I mentioned plus one rotary that will be working in the trigger/timing system. Do you think the Kflop alone can handle this, or is the Kanalog necessary as well?
Grace
On 11/18/2011 6:40 PM, Tom Kerekes wrote:
Hi Grace,
Sent: Monday, November 14, 2011 4:14 PM
Subject: [DynoMotion] New Machine Idea- Would KFlop be suitable?
Grace McKay
Group: DynoMotion Message: 2349 From: TKSOFT Date: 11/20/2011
Hi Grace,
Yes it didn't show up on the Yahoo Group. I don't know why Yahoo doesn't like you :}
Are the 3 encoders differential or single ended? That would be the only advantage I see the Kanalog would give you. It has differential encoder inputs which have more noise immunity. Unless you can also use the other IO it provides.
> Grace
> > Hi Grace,
> > trying to do.
> > *From:* Grace McKay <grace@...>
> > *To:* DynoMotion@yahoogroups.com
> > *Sent:* Monday, November 14, 2011 4:14 PM
> > *Subject:* [DynoMotion] New Machine Idea- Would KFlop be suitable?
> > my question(s)...
> > system.
> > Grace McKay
Group: DynoMotion Message: 2350 From: gracemckay Date: 11/20/2011
Hi Quelisto--
the frame rate will be somewhere in the 12 to 30 frame per second range. the camera is capable of 40 fps, but I think for the time being I am better off not approaching the limits. I am not sure what this term means- integration time-- can you clarify?
I do agree that getting the frame registration to work correctly is the key to the whole thing. I have several ideas about how to make that work. The first one is to use an optical encoder in the film path to sense motion and position of the film, and to use that info to trip both the camera shutter and the led strobe. If I can't make that work, second is to use an optical trigger looking at the film sprockets to do the trigger. A mechanical sprocket is also possible to drive the capture but is my last choice, at least right now. The idea is for the film to have a constant motion, with the frame capture to happen as the film passes the gate.
I have hopes that I can use the Kflop to handle the trigger signals, but that is something I will need to figure out. Maybe the Kanalog will have the functionality for that. My understanding of the whole system is at the extreme novice stage. So it will be fun to figure out.
The motor I have selected for the capstan is a brushed servo with an on-board encoder. I think you are right about a stepper being too rough for this application. I may want to use steppers for the reel motors, but probably servos will work better here as well.
Grace McKay
ScanBox
High Definition Motion Scanning
Scanbox.tv
> > question(s)...
> > knowledge flowing.
> > system.
> > Grace McKay
Group: DynoMotion Message: 2351 From: Tom Kerekes Date: 11/20/2011
Hi Grace,
My understanding of how most cameras work is the sensor's pixels are like tiny capacitors that charge up as light strikes them.  So they "integrate" the light over time.  In normal operation the image intensity is constant so the longer it is allowed to integrate the brighter the image is.  Then the chip reads out the charge for every pixel.  I assume in your case you are using an LED as basically a strobe light to freeze and capture the frame.
Here are some thoughts:
30 fps corresponds to 33ms per frame.
Assuming an accuracy of 1/2000th of a frame the trigger time would need an accuracy of ~16us.
KFLOP can't quite do that in software.  The best a KFLOP User program can do is execute every 90us (using the User callback every servo sample).
It seems like a hardware timer with microsecond resolution would be required.  You could do something like sample the capstan encoder position every 90us.  The last few 90us samples could be used to determine your average position and velocity.  Using the position and velocity information you could predict very precisely in the future when the capstan should arrive at the target position.  When the time to target becomes less than say 120us you could program the hardware timer to trigger at that time.
In order to syncronize the film position to the film sprockets, you might feed a optical sensor output into a Kanalog ADC.  The optical sensor should be configured/focused such that the ADC value ramps over a few 90us samples.  KFLOP could then use two or more samples to interpolate in time exactly when the signal crossed a threshold.  For example at one 90us sample the ADC reads -300, at the next -100, then +100.  We could assume it crossed zero 45us ago.
KFLOP doesn't currently have any programmable timers, but I think it might be possible to use a Step/Dir generator as a Timer.
Sounds like fun :}
Group: DynoMotion Message: 2355 From: himykabibble Date: 11/20/2011
Having been VP of Engineering for two different digital camera companies, this is something I know a little bit about. I think the bigger problem will be that, depending on exactly what device you are using to do the capture, the latency from the time you signal you want to do a capture, and when that capture actually occurs is likely to be quite significant, and quite variable from frame to frame. So, before you go any further, you need to understand exactly how the capture device you intend to use actually operates. In video mode, their frame rate is typically a function of their internal clocks, and you will have no control over that. Trying to do it as a rapid-fire sequence of still frames will not work, due to the time required to "setup" each frame - (AE, AF, color balance, etc). Nor will you be able to control the phase of the capture to your trigger signal in video mode. - the first frame will generally be captured some indeterminate period of time after to tell it to begin video capture. Doing what you're suggesting will likely require building your own capture device, and controlling the sensor and analog front end directly, which is non-trivial, especially if you're using a CCD, rather than a CMOS sensor.
Ray L.
> Hi Grace,
> Sounds like fun :}
> From: gracemckay <grace@...>
> Sent: Sunday, November 20, 2011 12:48 PM
> Subject: [DynoMotion] Re: New Machine Idea- Would KFlop be suitable?
> Hi Quelisto--
> Grace McKay
> ScanBox
> Scanbox.tv
> > > question(s)...
> > > knowledge flowing.
> > > system.
> > > Grace McKay
Group: DynoMotion Message: 2360 From: gracemckay Date: 11/20/2011
so it sounds like I could use the kfop to predict when the frame should arrive, but I can't know exactly. I anticipate some sort of manual adjustment to be available to visually adjust the framing to bring the frame lines into sync. Probably another rotary encoder that inputs a user adjustable offset to line things up correctly.
The camera system is essentially stop-motion- the film is moving and we take a snapshot of it at the correct time. I think I was calculating the shutter to be open no longer than around 6us to get a still frame. so we are taking a picture for only a small portion of the time between pictures. My test encoder has a resolution of 2500 pulses per revolution, which equals about 80 pulses per Super8 frame. So every 80 pulses I need to snap a picture.
I suppose a clock could be added that keeps track of all this stuff. But I am miles away from this right now. When the Kflop arrives I expect I will be facing a steep learning curve. Thanks for your input!
Grace McKay
ScanBox
Scanbox.tv
> Hi Grace,
> Sounds like fun :}
> Hi Quelisto--
> Grace McKay
> ScanBox
> Scanbox.tv
> > > question(s)...
> > > knowledge flowing.
> > > system.
> > > Grace McKay
Group: DynoMotion Message: 2361 From: gracemckay Date: 11/20/2011
Hi Ray,
The camera is a Prosilica GX1920. I hope to be using the still capture mode, which can go as fast as 40 frames per second, if I read the datasheet correctly. But you are right, I don't really know. The whole system is manual- manual focus, exposure, white balance, so I presume we will lose no time with those functions. As near as I can tell, the speed of the hard drive system is the constraint that will matter the most on how fast we can actually capture. The manufacturer is recommending a 4 drive hardware raid to go at normal speeds. Right now, I am still trying to figure out the transport stuff. If I can get 1 frame per second to start, I will consider that a victory. Ray, I am glad you are here, your background and knowledge may keep me from stepping in a mud puddle or two. Thanks!
Grace McKay
ScanBox
Scanbox.tv
> Regards,
> Ray L.
> --- In DynoMotion@yahoogroups.com, Tom Kerekes tk@ wrote:
> > Hi Grace,
> > Sounds like fun :}
> > From: gracemckay grace@
> > Hi Quelisto--
> > Grace McKay
> > ScanBox
> > Scanbox.tv
> > > > question(s)...
> > > > knowledge flowing.
> > > > system.
> > > > Grace McKay
Group: DynoMotion Message: 2366 From: himykabibble Date: 11/20/2011
Take a good look at pages 42-44 of the Prosilica Technical Manual, which spells out the latency, and latency jitter, from the time you request a capture, until it actually takes place. They can be quite short (1.5uSec, +/-0.5 uSec), under the right conditions, but you may not be able to provide those conditions at higher frame rates.
Ray L.
--- In DynoMotion@yahoogroups.com, "gracemckay" <grace@...> wrote:
> Hi Ray,
> or two. Thanks!
> Grace McKay
> ScanBox
> Scanbox.tv
> > Regards,
> > Ray L.
> > > Hi Grace,
> > > Â
> strobe light to freeze and capture the frame.Â
> > > Â
> > > Â
> > > Â
> > > Â
> servo sample).
> > > Â
> > > Â
> interpolate in time exactly when the signal crossed a threshold.Â
> > > Â
> might be possible to use a Step/Dir generator as a Timer.Â
> > > Â
> > > Sounds like fun :}
> > > Â
> > > Â
> > > Â
> > > Â
> > > Â
> > > Hi Quelisto--
> the gate.
> > > Grace McKay
> > > ScanBox
> > > Scanbox.tv
> torque ripple).
> is(are) my
> > > > > question(s)...
> digital
> choice
> 23
> matching
> of
> From my
> associated
> not? It
> starting
> me -- I
> or point
> exchange
> > > > > knowledge flowing.
> been
> machines I have
> If I can
> The
> BTS
> > > > > Quadra,
> some good
> the
> from
> sense the
> trigger,
> pulse. there
> motors (3)
> light
> > > > > system.
> > > > > Grace McKay
Group: DynoMotion Message: 2368 From: gracemckay Date: 11/21/2011
Thanks for that. I have seen that chart, but it has been awhile. It really defines what I need to know when I get to that stage. My design goals are really "design hopes" right now, as I have no clear understanding as to what is really possible. I will find out- I guess! I don't really need to make this thing run at more than 24 frames per second, although faster is better as far as overall productivity is concerned. But the main goal is to get a high quality capture, and I believe that will be possible. The camera really can pick up the detail I need.
I had envisioned the capture system to be adjustable. The timing between the camera, the film frame, the light flash, and the trigger all have some specific maximum speed that can be achieved, along with the accuracy and speed of each device, and any delay that is required. Perhaps I need a system clock that is fast enough to be faster that the camera, and trigger each device based on their own delay from the clock. Right now I have no idea how that could work in practice.
Thanks Guys for all the ideas!
Grace
> Regards,
> Ray L.
> --- In DynoMotion@yahoogroups.com, "gracemckay" <grace@> wrote:
> > Hi Ray,
> > or two. Thanks!
> > Grace McKay
> > ScanBox
> > Scanbox.tv
> > > Regards,
> > > Ray L.
> > > > Hi Grace,
> > > > Â
> > > > Â
> > > > Â
> > > > Â
> > > > Â
> > servo sample).
> > > > Â
> > > > Â
> > > > Â
> > > > Â
> > > > Sounds like fun :}
> > > > Â
> > > > TK
> > > > Â
> > > > Â
> > > > Â
> > > > Â
> > > > Hi Quelisto--
> > the gate.
> > > > Grace McKay
> > > > ScanBox
> > > > Scanbox.tv
> > torque ripple).
> > is(are) my
> > > > > > question(s)...
> > digital
> > choice
> > 23
> > matching
> > of
> > From my
> > associated
> > not? It
> > starting
> > me -- I
> > or point
> > exchange
> > > > > > knowledge flowing.
> > been
> > machines I have
> > If I can
> > The
> > BTS
> > > > > > Quadra,
> > some good
> > the
> > from
> > sense the
> > trigger,
> > pulse. there
> > motors (3)
> > light
> > > > > > system.
> > > > > > Grace McKay
